87 With 2.9L Running Like Crap
cedave
Barstow, CA
I have an 87 2.9L V6, auto trans, 2wheel drive, dual tanks. I've changed the fuel pumps in the tank and the HP pump on the frame rail, changed fuel filter, the spark plugs and wires, changed the fuel pressure regulator (napa), changed the MAP sensor, changed oil & filter, changed air filter, but the truck still runs like crap, seems like it is missing real bad. It starts up just fine but has a rough idle and some times after idling for a couple minutes the rpms will slowly surge up and down then it will eventually die. It doesn't do this all the time though, some times it will just sit there with a rough idle and not die. When I try to rev the engine it will bog and hesitate and then eventually rev up. Has anyone out there experienced these symptoms? What do you recommend? I'm at my wits end with this thing. It used to run really good!!!!! Also, the truck had sat for several years before now, so i drained out all the old gas in the tank when i changed the in-tank fuel pump (the old pump was totally seized up). The inside of the tank looked very clean. Please Help!!!!!!:dunno:
Sounds like the exact same thing my truck is doing. And not to say it is, but I have narrowed my down to a collasped lifter. AS I have also done everthing thing that you've mentioned.
Tried an IAC yet? Also check for vacuum leak and a clogged cat. Wouldn't hurt to check compression as well.
OK, get this, cleanded the IAC and it seemed to help the up and down idle a bit but it was still missing really bad. So i pulled the plugs and did a compression test and discovered i had two dead cylinders (1 & 3). So I pulled the valve cover and found both intake push rods just laying there. Apparently when i was reving it up earlier in my other diagnostic attempts (before i changed the seized pump in the tank) i over revved it, floated the valves and it dropped the two push rods. Anyway, their not bent so i put them back in and adjusted the valves/rocker-arms. Put the thing all back together and now it runs fairly good, however, it still has a slight hesitation when accelerating and there is still a very slight miss (slightly rough idle) especially when it is idling down after reving it up. I noticed now that my brand new fuel pressure regulator (NAPA) is dripping fuel when i remove the vacuum line, so i guess i will have to return it. Hopefully that is what is causing the slightly rough idle. Do you guys have any other thoughts? This thing used to pur like a kitten.:dunno:
