Aadams_4440
I have finally managed to get my 87 manual to start and run. Definitely doesn’t run 100 percent and surges. Timing was set at 10 degrees Btdc https://youtube.com/shorts/RFoHK98-2-A?feature=share
If its smoking under the hood its probably valve cover gaskets leaking oil on the manifolds, getting hot, and burning off. Its a common 2.9 thinghttps://youtube.com/shorts/REGb7fhEeAQ?feature=share
it’s purring but I’m pretty sure the valve seals are leaking and causing it to burn oil out the exhaust manifold. Is it worth messing or should I swap it ?
