86 ranger body lift questions
Welpracing
What does a 3" body lift on a 86 ranger come with? a friend of mine gave me his 3" blocks off his yota and if it is not a whole lot of trouble i would like to just use them instead of buying a kit. what all will i need to fab up?
if i have this in the wrong spot could some one please move. Thanks!
it comes with the blocks, a steering shaft extinder, and if a manual trans a extension for the shifter. some kits you can get the bumper rizers and the gap gaurds.
i hope this helps.
My PA only came with blocks, hardware and steering extension.
I had to make the 4wd shift extension and bumper brackets myself, I don't know of a kit that includes them for a first generation truck. A filler extension is not needed.
Same here. For the most part it's pretty strait forward but I would recommend getting new poly body mount bushings and make your own or buy sleeves.
