What kind of backspacing would those of you with experience recommend for the tire to clear the leaf spring at an acceptable turn radius?
Of course it will be wide but I would like to trim as many inches off as I can, yet not butcher your turn radius? i.e. of course H1 wheels that have 6" of backspacing would narrow it up but you'd "have the turn radius of a boat."
Ideally I like the looks of 4" or so of backspacing but would go for 3.5" or 3" if it'd help out on tire to spring clearance. I don't want to do 2.5" or less when you can clearly see the rotor outside of the wheel. I already have the 42x15" tsl's, bigger than I had initially planned but got a good deal on them so that's what I'm running. I would like to run a 10" wheel, but again, if an 8" would narrow it up to vastly improve tire to spring clearance at full lock, I'll run an 8". I have weld on bead locks too if that means anything in determining wheel width.
