YungICY
- Jul 19, 2013
Hey guys I have a bit of a brain teaser that I need some input on. I can't tell if my engine is running hot or cold.
First things first I'll give you a breakdown of the truck.
It's a mildly built 2.3. Shaved head, big cam, holley 350 cfm carb, esslinger underdrive power pulley and water pump pulley (stock water pump & 192 stat).
I have aftermarket gauges on the inside (equuis). The temp gauge uses some kind of pressurized tube that runs to a probe that I have in the stock location on the block.
Here's where things get interesting. The stat is definitely opening because the upper hose gets plenty hot. The radiator (stock) will get warm after a while and the lower hose will get warm after a while but cool enough to grab. The temp gauge tells me I'm running at like 170 degrees.
I can only logically think that as the cooled coolant goes back into the engine it is only hitting 170 as it passes by the temp probe and 192 or higher by the time it gets to the stat but that seems somewhat unlikely. Or that the gauge could just be out of calibration.
Also one other tidbit is that the carb is running a little rich.
And anyone shed some light on this?
Sent from my LGMS345 using Tapatalk
