'85 Ranger Restomod
My dad put the intermittent wiper switch on mine years ago, plug and play, but it has always had a dead spot right where you want them to run. Couldn't find the same style turn signal switch that operates my horn on my truck so I have one that has cruise control that I can't use. However its a longer lever switch which is nice. I just use my finger and engine as a horn instead.
If it is any consolation the later ones like mine with a horn in the middle use a contact switch that rides on a ring. The tiny springs like to break in them and nobody makes them aftermarket... so I am in the same boat for a horn.
I had that problem, then I just started looking in the junkyard for anything with the same style contacts and changed the springs/contacts in my plastic housing.. The housing is held together with 2 little aluminum rivets that aren't hard to remove. It is a PITA to re-assemble though.
It is low enough on my to-do list I just haven't gotten to it yet.
Its been 15 years already since this little guy followed me home.
'85 Ranger Restomod
Now that I think about it it was in 2000 that my dad brought what is now my truck home. $500 off the side of the road.
Cool
Anyway I got some more done to my axle. Starting with the passenger side since it is simpler and easier to wrangle around.
Hauled it to work last Saturday so I could introduce it to smokey the blue flame wrench. :icon_welder:
This ugly bugger.
'85 Ranger Restomod
'85 Ranger Restomod
Once it cooled off
'85 Ranger Restomod
The other side played nice.
'85 Ranger Restomod
Ready to operate at home.
'85 Ranger Restomod
'85 Ranger Restomod
That had to make a neat noise.
'85 Ranger Restomod
Basically have it stripped down to this, the block for the ABS sensor is off. The harness made me mad because it was always in the way so it got cut off the sensor. The spindle has yet to come off the knuckle though.
'85 Ranger Restomod
Nice on what it takes to make things that are old to do what you want.
Knuckle is off. :yahoo:
Had dad look at it and he used his bearing punch (old flattened chisel) and a hammer and walked the spindle out of the knuckle.
From there I could get to the lower ball joint and rattle the nut off. My harbor freight ball joint press worked great to punch out the two ball joints. Lower was loose and needed replaced, upper didn't move at all so it is good I am replacing them. The axle cross has a little slop in it too (although nowhere nearly as loose as what is in the truck)
'85 Ranger Restomod
'85 Ranger Restomod
'85 Ranger Restomod
Now to wire wheel and paint so I can start going back together. :D
Kinda glad I decided to splurge and put crosses in the front... I lost no rollers out of the caps either.
'85 Ranger Restomod
Man. This looks like what I just went through on my Dana 35. I did balljoints, bushings, etc.
Love your truck! Looks great man.
That would have caused problems quickly.
