- Aug 30, 2007
- Oklahoma
- Automatic
I just use my finger and engine as a horn instead.
Just Beautiful, Like Poetry!
FrankBoss
My dad put the intermittent wiper switch on mine years ago, plug and play, but it has always had a dead spot right where you want them to run. Couldn't find the same style turn signal switch that operates my horn on my truck so I have one that has cruise control that I can't use. However its a longer lever switch which is nice. I just use my finger and engine as a horn instead.
If it is any consolation the later ones like mine with a horn in the middle use a contact switch that rides on a ring. The tiny springs like to break in them and nobody makes them aftermarket... so I am in the same boat for a horn.
I had that problem, then I just started looking in the junkyard for anything with the same style contacts and changed the springs/contacts in my plastic housing.. The housing is held together with 2 little aluminum rivets that aren't hard to remove. It is a PITA to re-assemble though.
Now that I think about it it was in 2000 that my dad brought what is now my truck home. $500 off the side of the road.
Nice on what it takes to make things that are old to do what you want.
That would have caused problems quickly.
