85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
On a unrelated to the engine but very related to the swap I drug my tranny back out of the shed and got it ready to clean up and maybe paint (that aluminum paint is kind a fun to use)
Anyway I notice it has a hump in the pan, which I think means the guts of it is a C5. Neither the tailhousing or the bellhousing really look like it matches the center section so it could be a V8 C5 for all I know.
The guy I got it from had it in I think a '84 BII a couple of years ago, with a 302 of unknown year and 1350M t-case. I got there just as he was unbolting the TC from the flexplate, the fluid under the tranny looked perfect. BII was being parted because of terminal rust, body was gone it was just a rolling chassis when I got there.
I have heard that some parts inside need to be changed for a V8 swap. I think it is just the TC, valve body and front pump that needs changed, the TC probably is ok since it was on a 302 but how do you check the others?
What do I need to do to make sure this thing is safe for a overall pretty tame 302?
The spacer plate that goes between the engine, are there different thicknesses of those or all they pretty standard? While dragging out my C4 I found the plate for my 289 which looks like a direct match for the starter hole.
Edit, Pics added,:
Bellhousing decodes as a 82 design for a fullsize Ford, automatic... not really that helpfull.
The number reads as a E0AP, 1980 fullsize Ford, automatic. Didn't see a casting # on the case, it still has fluid in it and it dumps out if it isn't sitting just right. Dunno where to look yet either.
Edit, Pics added,:
