85rangerdanger
I took the compressor off since it doesn't work but don't know what to do about the two hoses connecting to it can I just take them off?
Would I still have heat ig I just took those two hoses that connect to it and just cut them off ?
How am I supposed to know if I'm asking it
Also, if the air conditioning is already non-functional but the heat still works, then it can be concluded that removing the air conditioning components should be ok.I am trying to encourage critical thinking. All cars have heat. Not all cars have air conditioning. So by that logic if you remove the air conditioning parts the heat should still work.
This message composed solely of recycled electrons. Go green!
I'm new to all of this I've never taken a smog pump off or deleted the A/c I bought this truck as a project and haven't evits gave it it's first test drive I got it running but the brake pedal is really hard and I have to press hard for it to stop in gear just in the drive way I'd really appreciate all the info and help I could get on all the upcoming work thank you in advance
