Jason_1984
- Mar 10, 2015
Hello I'm new to the website. I have a 1983 Ford Ranger 2.3 manual 4 speed that is idling extremely rough. I lined up all the timing marks on cam and crank and rotor was pointing at cylinder #1. Undid the Vacuum line to the distributor. According to the timing light I am at 20 BTDC at idle. If I am not mistaken this is supposed to be at 6BTDC at idle. If I put to 6BTDC with timing light it almost dies (and doesn't seem to really line up with #1 one anymore) . I have triple checked cam and crank timing marks and that the rotor points at #1. I am getting a pretty strong exhaust smell but no visible smoke. If I am not mistaken there should not be a "tooth off" situation because I can turn the distributor right?? Anyways I need some help. If anybody has any insight please let me know.
Recently did head gasket. Had valves machined by a machine shop. New plugs, wires, cap, and rotor. New Coil. New Distributor. New timing belt. Replaced the PCV valve. New Carburetor. Most vacuum lines replaced. Has compression. Also replaced the ignition module.
I am thinking there is a component that is delaying my ignition. If anybody has any input/ideas it is greatly appreciated. Its driving me crazy!!!
