juice90
- Jul 12, 2014
Hi all... My truck is a 94 Mazda B4000 4x4 and has a trac lok 8.8 with 3.73 ratio and 28 spline axles. The clutch packs have gernaded in my diff and I want to rebuild it.
Most everything is ok in the diff with the exception of the spider gears. When the packs came apart, the spider gears ground everything up and as a result the spiders have chunks missing and need to be replaced
Wondering if the spider gears have to be from a trac lock diff? Or can I use any gears from an 8.8 or 7 inch as long as they are 28 spline?
I have found several used sets for sale online, but often they came from and "open" diff.
Thanks for the help
Thanks for the help
