sgtsandman
Automotive Technician
TRS 25th Anniversary
Ham Radio Operator
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
Amazon sells the tool kit. I think the brand name is OTC.I've learned over the years that common sense helps out a lot and that's a good idea on labeling everything. One of main concerns someone mentioned already is manifold studs. As rust free as my truck is they still look like they would break if you looked at them wrong haha. I'm sure they are even worse on the donor truck that most likely has lived in Maine it's whole life. When those break are they easy to remove or do they need to be drilled out usually?
Looking the service manual, it looks like you only need 4 "special" tools and none of them are really special. Also the manual has step by step instructions for me to follow. Worse comes to worse my neighbor is an old fellow who is a retired mechanic and he has ALL the tools and knowledge I just hate to bother him too much. I've seen him doing a few engine swaps in his driveway for people in the past though....
Depending on how the studs break, you may be able to use a stud removal tool, drill out the center and use an extractor tool, or weld a nut onto the stud and wrench it out. You will want the stud tool to install the new ones or double nut the stud and wrench them in. It might not be a bad idea to have nut extractor sockets since the nuts are probably going to be less than nut shaped.
