DiscoDan
Ok, so i have a '92 ranger with a 2.3 5sp and its only 2wd. i just got it about two weeks ago and now running into problems. first off whenever i have the clutch engaged it makes a whining noise. checked the clutch fluid and its fine. still have no idea what it is.. besides that i was coming up to a stop light and pressed the cluth pedal and had no pressure. i had to pump the pedal to build pressure (guessing that the slave going out?). ALSO i was driving today and heard a loud pop from the transmission and now whenever i let out the clutch its whines/grinds extremly loud in every gear excecpt 4th isnt as bad. any ideas on what it could be would be awsome. thank you in advanced!
