4x4 v8 Ranger
Thanks guys it was a fun race and we worked really well as a team it was a good way to finish the season.
a quote from my dad at the finish line.
DAN CHAMLEE, No. 700 (First in class.) We did all the silt beds and hill climbs and never got stuck but we did have a third member break and cooling fan failure. It was a completely different brand and style of fan and it turned out to be defective. We took a spare with us, kept going and the new one was fine. We just couldn't believe it (after having several fan failures in past races.) I get within 100 miles and I think we are home free and something breaks. The broken third member took about an hour and a half to repair.
sent by another dumbass using Tapatalk.
I built a seat that goes in the receiver so I don't have to walk during contingency. Also will work good to strap parts to to run into the course
4x4 v8 Ranger
4x4 v8 Ranger
talking to the competition
4x4 v8 Ranger
Gotta love baja
4x4 v8 Ranger
Random baja pics.
4x4 v8 Ranger
slightly used tire for sale.
4x4 v8 Ranger
see u next time ensenada
4x4 v8 Ranger
Some more updates. I think we have decided to go ahead and build the 302 that is in the truck now instead of looking around for a 351. It's going to get the truck up and running much quicker and easier since the first race is just over a month away. We might still switch to a 351 based motor someday as well as 4.0 shocks.
We got rid of even more of the frame. The frame ends just after the radius arms.
4x4 v8 Ranger
4x4 v8 Ranger
ill be picking up a cab for the truck Sunday.
more pics
4x4 v8 Ranger
Spider-web
4x4 v8 Ranger
4x4 v8 Ranger
4x4 v8 Ranger
Started cycling suspension, first try 22in. Final #s 25in of travel.
Radiator and fuel cell. Check..
4x4 v8 Ranger
our letter to MORE.
The rules look good. $500 entry fee with a payback is ok with us. Regarding rule #2 To make the rule more fair to everyone with different cab sizes allowing the frame to end at the rear suspension pick up or rear of transmission would be better. This way you are not required to leave more of the frame just because you have an extracab or crewcab.
Think I've notched a few tubes recently
4x4 v8 Ranger
Picked up some important pieces for the truck today.
Got the new hubs in so my dads spares can go back in the Chase truck and we can assemble the front and rear axles. We don't have the driveplates/hubcentrics yet so we can't actually bolt on tires. but we can put on the hubs and axles andeverything else so it should be sitting on it's own wheels soon.
4x4 v8 Ranger
got a lot of work to do on the cab. It's got to be completely stripped so we can cut the floor out of it and slip it over the cage.
4x4 v8 Ranger
More new parts. Free 5.0 can't complain about that.
4x4 v8 Ranger
Starting pulling the cab apart, this is gonna be a lot of work...
4x4 v8 Ranger
The cab should sit about here.
4x4 v8 Ranger
Got the rear shocks mounted. Just needs some more gussets to the tabs
Lots of updates.
We have the cab cut apart and ready to start fitting over the cage.
4x4 v8 Ranger
we got the seats and petals mounted. Clutch and gas are hooked up. Brakes just need lines run. The headers are almost done, we only have one tube left to make for the drivers side rear cylinder.
4x4 v8 Ranger
4x4 v8 Ranger
4x4 v8 Ranger
4x4 v8 Ranger
We started on the dash and cut the hood to fit In place so we can see if the dash is too tall.
4x4 v8 Ranger
4x4 v8 Ranger
Idk why Tapatalk is being gay and won't let me upload pics
brakes/hubs hooked up
4x4 v8 Ranger
Fuel lines/heat shield for exhaust
4x4 v8 Ranger
I got a new camera so had to take some pics of my prerunner
4x4 v8 Ranger
4x4 v8 Ranger
We are using the stock mustang clutch cable and made a bracket to attach it to a cnc pedal assembly so we don't have to worry about boiling clutch fluid next to the exhaust
4x4 v8 Ranger
