4x4 manual locking hub problems 98 ranger.
Southenrfirewood
Iv got a set of manual locking hubs on my 98 ranger because the automatic hubs stopped working or would work sometimes. I put a set of rugged ridge ones on and to make a long story short Iv bought 3 sets and got one extra under warenty from the dealer now iv gone though 7 hubs and I now have none. What do I do? Im putting them on correctly they work for a few months and they fail. thought the first set failed because my wheel barrings where going out but after I changed them they till kept breaking. Some completly blow appart some wont disengage completly they have a variety of problems. What should I do? Seems like the first time I go in mud they fail
Is there any other brand of locking hubs that will fit besides the AVM or Rugged ridge hubs?
Oh I see it now. But wait isn't it bad to have them locked all the time? I herd it would tear stuff up
There is another write up of something similar to this except he cut that little screen out and you can lock and unlock the hubs using your finger. It works like a pen kinda, when you push it in all the way it locks your hubs and when you push it again half way it unlocks.
Wont that destroy the front end, transfer case, Cv axles Ect? Esspecailly on the hwy
No. Its better than the manual hubs you have, obviously if you've gone through 7 of them, because it's just a modified OEM part. If you leave them locked in all the time it will start to slowly wear on parts but you wouldn't be replacing parts left and right. Rangers from 2000 1/2 and up have a live axle (hubs locked in all the time) so its not bad for it. Quit wasting your money on those aftermarket hubs and just modify the part that came with your truck. I did this to my 98 almost a year ago and haven't looked back.
It is actually safe to drive around with the front end locked in as long as the transfer case is disengaged. The only thing it does is put a little extra wear on the front u-joints. You will have to keep an eye on them too.
This guy drove around with his hubs locked in all the time and had a u-joint lock up at about 75 miles an hour:
That is NOT typical results though. I have driven many thousands of miles with my front hubs locked and noticed nothing worse than a little extra vibration around 65 to 70.
Well that sure makes me feel all warm and fuzzy about doing it! Lmao Another big reason I like being able to unlock them is I use the truck in 2wd vs. 2wd truck pulls and I put my truck in 4wd low and leave the hubs unlocked. It gives me a huge advantage in the torque factor.
Im going to bet the problem has nothing to do with the hubs.
If your killing them that often and you are playin in the water and mud thats a sure sign that the huge seal on the back side of the knuckle is bad where the CV shaft seals.
I had the same issue on my 99 until I realized that after 2 sets of AVM hubs that water and dirt was getting inside my hubs from the backside where that seal was completely trashed and tore.
This is a shot of the inside of my knuckle after trashing another wheel bearing which took out the hub.
Seal I speak of.
Seal installed.
How it should look.
Seals to the larger flange on the outer part of the CV
The 2000+ Rangers have the EXACT same front axle and suspension setup you have....except they don't have locking hubs. The "hubs" are locked in all the time, even in 2wd. (Seems even Ford realized using hubs was too much of a pain in the ass and finally decided to do away with them altogether) By converting your truck to the "permanently locked" setup, you'd basically have the same setup as a newer Ranger. Driving around with hubs locked in doesn't damage anything. Only driving in 4wd on dry pavement does damage.
I don't see how this applies to 1998+ Rangers that use CV joints, not U-joints.
I changed the whole assembly for the wheel barrings recently and put a new set of hubs on. it burned them up. Is the seal appart of that assembly. Also I love the manual lockers because i leave them unlocked and put the truck in 4wd low and enter 2wd truck pulls and it gives me a ton of tourch
