4x4 Low not working.
freestyletrev
4x4 Module Pin Out/Wiring Diagram
Hello, this is my first post!
I have read around this site and many others and still cannot find exactly what I need.
98 Ranger XLT-4.0-5spd
My 4x4 high works fine. I can switch between 2wd and 4x4 high with no problems. It will not however switch into 4x4 low. There is no relay click from the shift module. I imagine one of the sensors is not working properly. I took the TC motor off and it works fine in both directions. I can also manually turn the TC into 4x4 low. I did try another switch and same issues, so I am ruling that out.
I was hoping someone could give me the pinout of the 4x4 module that is located directly behind the GEM, so that I can ground/connect to 12v via a switch so that I can override the sensors. I have searched everywhere and haven't located one. If this doesn't work, then I will try a new 4x4 module or whatever suggestions you guys may have.
Thanks in advance!
Does anyone have any clue about this?
Yes. I would like to narrow it down to one sensor that isn't working. I believe the speed sensor is okay because my speedo works and my neutral safety switch is fine because I can start the truck fine. Does that sound correct?
