Jody
I have gone through the steps on this tech article http://www.therangerstation.com/tech_library/4wd_control_module.html and still cannot get this to function.
1994 Ranger super cab, I have replaced the module and the new one tests as working. I have three different motors that I have verified all functioning. Fuses are good. The switch panel tests good also. When I plug everything in nothing happens. Sometimes when I start the truck the indicator will show 4hi or 4lo engaged but I know it is not. I have no issue with the transfer case or the hubs as I can manually shift it into 4hi or 4lo and it works fine. I just cannot get the electric shift to work.
Any ideas on what I should look for or test next?
