FarmerJohn
- May 15, 2009
- Automatic
1999 Ford Ranger 4.0l Automatic 4wd
Here is the situation. Thanks in advance for your help.
Background:
I had two cracked heads on my engine, so I replaced it with a used engine. When I pulled the engine I pulled the torque converter(TC) with it. When I put the engine back in, I bolted the TC to the flywheel and put the engine in. I turned the engine over in both directions until the bellhousing was flush with the block and then I bolted it together. No engine problems at all, but the transmission is giving me fits.
Problem:
While going down the road, within the first 5-10 miles, the O/D light starts to flash. The tranny goes into it's limp mode and then the tranny shifts hard. I took it to the dealer, they said the torque converter is not good, and maybe more. That's truly absurd. There were no problems before. In doing some reading, I decided maybe I didn't get the TC to seat fully. I thought that maybe the TC was seated into the pump and therefore not driving the pump to give fluid to the TC. Seemed like I just made a rookie mistake. So, I pulled the tranny to reseat the TC. With the tranny off I seated the TC until it hit the bellhousing, everything seemed normal. I pulled the pan to check for fluid and fillings and such. Not really any fillings or major clutch dust to speak of. A few sparkles, nothing out of the ordinary for 175k miles. I buttoned everything up, and put the tranny back in. The problems persists. By the way, when the O/D light is flashing, no OBD code is present. I have checked many times.
Question:
In doing more reading, I am going to investigate the following possiblities:
- TPS not giving correct readings - possible since it's a different engine
- TCC Solenoid - not likely, it was fine before
- Brake Switch - again, it worked before
- I'm going to pull a cooler line to confirm that the tranny is pumping fluid
- I will disconnect the battery and allow the computer to reset
What else should I be looking at? Did I mess up the pump during the first install? Did I screw up the TC? Shouldn't there be fillings in the ATF if I did? Anyone else had similar issues? Thanks for your help.
Background:
Problem:
Question:
