- Aug 22, 2012
- Automatic
ok everyone knows they exists but no one seems to know much about um. ive read up on them over the past couple days as i am thinking of swaping one into my 94 4.0. i can get everything i need motor tranny transfer case innercooler the whole shebang for $600 which is a good deal to me. the only thing is the guy who is my friend has 2. one is blown up with the tranny and t case and is turboed. the other is non tuboed and running he is going to swap the turbo over for me. but as ive found the non turboed version is actually a 2.2l from mazda so idk if itll work. i want to make a performance motor out of it. any help is greatly appreciated!!
for anyone looking to do this swap heres all ive gathered so far:
-THESE ENGINES MUST STAY COOL! if you swap a inner cooler is a must!
-If you swap you should deffinetly change the timming belt theyre known to blow and take out many parts with them
- parts can be had from ebay.uk and many other places over seas (Australia for sure) as they are still in use there
-most of the 4d56 parts are inter changeable
-stock hp: 86 torque: 105
-stock psi: 10-12
-M5od R-1 trannys wont work as the bell housing cannot be swaped
-they operate with a VE type injection pump so can be tuned
-i forgot the stock turbo size but a t3 turbo fits and is bigger
-EVERYONE will tell you to leave it stock or itll blow but im pretty sure theyll hold 20 + psi and ARB makes head studs for them
-There has been people take these things OVER 200+ foot pounds of torque
-If you ask me any question you may have, i could probably answer it. I know quiet a bit more about them thats slipping my mind haha
-stock psi: 10-12
