4 inch BDS suspension Lift
Rescuer
St.Louis Missouri
I just bought a 4 inch BDS suspension lift kit off a guy and before i put it on i was wondering if anyone else has this lift and if they can post pictures to see wat mine might look like. Also the flat plate in the kit, where does it go.
Might want to try in the 4x4 suspensions. This is more custom long travel type suspensions, not really off the shelf drop bracket lift kits.
I tried looking into the 4x4 section and it linked me to BDS website i still dont see where one bracket goes.
Hmmm, I really don't know, I only really know I-beams. Maybe post some pictures and someone might be able to figure it out? I think a lot of the bracket suspension lifts are pretty similar.
EDIT: Thought you had A-Arms for some reason.
First off, ask in a different section next time.
To answer your question, the flat plate is used to drop the passenger side beam bracket down. If you have a Dana 35 front axle, be prepared to replace the center section when the plate punctures a hole in the center.
