4 gear shift solenoid..is there one?
maisy
The colonyb. Texas
Hey yall i gota 2004 mazda b3000 v6 3.0 with the 5r44e tranny. If i put it in drive and go when it get.to the point to shift in to 4th gear it.staus stuck in 3rd and then the o.d. off light flashes. Also reversing up hil is difficult. Fluid is full and pink..i have head peeps say shift solenoid ive had peeps tell.me that its the mechanical clutch inside the tranny that controls 4th gear. Pull pan n filter check the soloinds even though i have no idea wich is one is what. I can trick the tanny into worki g without o.d. light coming on. Tricking.. start on 2nd run up to 4k rpm or lil higher and then shift to the D pposotion and let off gas then shifts to 5 and if i can keep it above 60 mph . It makes thebtrubk think it is at high speed and should be in 4thbor th gear. Any help or advice
