Ive looked online but cant really find a good year range of which 4.6's were prone to oil burning? I think it was 91-94ish but does anyone know? Or are they all prone to it?
2010 Ford F150
It's puff the magic dragon design, it burns when it's too hot outside and running for multiple weeks then stops.
Thought I blew a head last summer unrelated, no it was just so hot that the water evaporated out of the old coolant.
Seriously work on the Ranger every week, the 4.6 just collected so much dirt and dust because you really just stare at it
If your not tearing it down to do ring job use the V6 bottle engine restore your next oil change.
Don't use the appropriate sized can you want more high mileage oil than additive, if the problem is minor eventually you can just stop using it and go back to oil.
I've let the oil go to 8k but been using high mileage full synthetic and extended filter.
Doesn't matter what oil though once you get closer to time it eventually starts to eat the oil.
So if your 4.6 is burning only a little it is a minor intermittent issue, up your quality of oil full synthetic can withstand more abuse, if that didn't help try a few changes with the additive no sense in cracking open the engine if it's minor.
Wife's truck so it has a weak lifter also, it's common on 4.6 so ALWAYS let the truck idle from cold for a minute. Big engine.. Changed battery today after 4 years and since I rarely pop the hood I forgot how big it was
it's not the type of engine you want to run less oil in ever even the old pushrods you didn't want to they tend to blow very quick if you neglect even a quart.
