Tulsa Time
- May 22, 2008
- Automatic
I am getting ready to use my '94 4.0. When I was driving it every day, I don't remember any significant valve train noise. However, after sitting for a while, anytime I would start it to move the truck the engine was quite noisy. I know the 4.0 is prone to rocker arm to pushrod wear.
This raises a couple of questions:
1- Could the noise just be from the lifters bleeding off while sitting? I let it run several minutes once and it never got quieter.
2-If I replace the rockers and/or pushrods, where can I get rocker shaft bolts? Since they are torque to yield and this seems to be a common issue, I would think they would be readily available. Yet I haven't been able to locate them in the aftermarket world.
Any opinions/advice from you 4.0 gurus would be appreciated.
