4.0 sohc feels low on power
White_4x4Ranger
Wenatchee, WA
31”
Lately I have noticed that the 4.0 in my 2003 ranger 4x4 feels sluggish, and it getting terrible gas mileage, around 11 mpg. Any ideas what it may be? Engine sounds good ( no ticking or annything of that nature) and doesn’t have any issues. 187k miles.
Check engine on?
Put a vacuum gauge on it...i cant remember exactly what the readings would be...but im wondering if you got a plugged cat
I’ll look into that. I just put some injection cleaner in the tank just to see if it does anything. Thanks.
Fuel mileage drop in the winter. My 4.0L gets 16 to 18 in the summer and drops to 13 to 15 in winter. Fuel blend... warm up time adds up to the lower numbers. 11 mpg is pretty low.
You ever smell fuel?
Does it blow black smoke?
Low on power is another thing. You check for throttle cable stretch?
Also... have you ever changed O2 sensors?
Also, would the check engine light come on if it was running rich or if some of the sensors were dirty, like the mass air flow?
It would if it couldn't compensate.
Good to know that it might just be the weather. I’m in central Washington and it is around 30-40 daily and gets into the 10-20 at night. Fahrenheit by the way. No black smoke, a fair amount of white stuff tho, might just be steam or whatever else comes out of tailpipes in the winter, just like other cars. I bought the truck used from its first owner, not sure if they ever did O2 sensors. I haven’t checked the throttle cable will do that though.
Yes it can...
Its not losing coolant is it?
Not that I know of. I haven’t seen any spots beneath it and it doesn’t overheat
Just trying to rule out a bad head/head gasket. Chances are the steam is just condensation but id check your radiator and overflow tank to make sure its full
I hope it’s not a bad head or head gasket. Ive worked on small engines before and have done a top and bottom end on a Kawasaki dirtbike but I’m really intimidated by a truck engine. Not so much by the engine itself, but more so all the other crap in the engine bay I’d have to deal with.
