- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Hey folks,
I know I haven't been around much in a while, but I need help.
For a while now my 99 Ranger (4.0, 4x4, Auto, 120+K miles) has been having an idle problem where it would idle rough as hell when first started up. It was most noticeable after you first started it and shifted into reverse, after maybe 10-15 seconds it'd smooth out and idle properly.
Yesterday when I was coming home from work I noticed that the engine was running a little funny. When I was cruising along at highway speeds, with no abrupt changes in speed, it felt like a motorcycle that's about to run out of gas (at least that's the best way I can describe it). Going on the thought that it may not be getting enough fuel I assumed it may be the fuel pump or regulator, so I did a pressure test. Well the dang thing holds steady at 60-62 psi in both KOEO and engine idling tests.
I had thought about bad gas but I drove the truck back and forth to work for 2 days with no problems on the same tank of gas, and it's the same station I used for my previous couple of fill ups with no problems. No CEL either FWIW, may not have driven it enough to get one since the problem started though.
Any suggestions as to where my problems may lie or other tests to perform?
