You will hear alot of people say this or that, if you have the FM146 it will bolt right up. A LOT of people will say "It will not hold the power" I think they are wrong. I have a FM146 behind my 4.0 for almost two years now. And I am NOT easy on it, I do 3-4k Clutch drops, Red lines "racing" and spinning in the mud. As long as you keep the fluid changed and good it will last. Btw it also a 4x4 so it also handle 4x4 low and high power, and I'm also not easy on it doing that stuff. All in All, a 4.0 swap SUPER easy, and I also use the same axles (7.5 rear/Dana28 front with 31's) and I've done stuff that people say I shouldn't do without snapping an axle but i have not yet. But if you plan to run bigger tires those axles will not handle them, 31's the max i''d say you can go before snapping them doing something "Rough," if you went with 5.0...You would have to replace a lot of things to handle the power.
