2000 explorer, 4.0 ohv, Mysterious loss of coolant, Smoke on start up, Exhaust smells like coolant. NO combustion in the coolant. coolant system pressure test shows no leaks.
Cyl. #4 misfire, 150 lbs compression, Good spark. Misfire is intermittent.
Ford says it is a head gasket, What do you think?
I was hoping for an intake gasket. I will probably be pulling the heads tomorrow after noon.
