likeshills08
- Dec 14, 2010
So, earlier today I purchased a 1989 fullsize bronco for 400a bucks. Has a 351w and c6. My ranger is a 93 reg cabtill shortbed 3.0l with a m5od, 3.73s on 37s... obviously underpowered. Figured this bronco would be a perfect donor vehicle. So Ive read thru the v8 swap tech article several times and also the james duff reccomendation v8 swap page and there is sparce information on the actual 351w swap. I plan to swap the entire drivetrain and ecm harness and splice it to the ranger body harness. I am just trying to figure out what parts are swap in bolton and what i absolutely need to modify. The engine mounts are a gimme.
However i have yet to find a set of headers that will work.
If the deck height is taller will the advance adapter shorty headers work for a 4wd? I read thru the header sticky and all i saw was the uses of headers on 302s. None for 351s.
Also i also noticed there was little information on the fullsize transmissions and t-cases. Figuring that since the broncos wheelbase is close to that of a ranger then length is not a problem. However width is a question. Does the t-case from the fullsize truck interfere with the d-side frame rail?
Does the 4.0l radiator sufficiently cool a 5.8? A c6 or e4od?
These are just a few things off the top of my head that slightly bothered me. Im just trying to figure out what has worked specifically in a 351w swap. Thanks
Thanks guys!
Drew
Thanks guys!
Drew
