351C V8 Ranger MOD?
HOT_ROD_CAR
Excuse my ignorance :idiot:
What are my transmission options, both manual and automatic, for a 351C (DOAE-L and D2AE-CA)? Will a AOD bolt up? This is for a everyday driver, stock 351C. Any info will be appreciated. Thank you.
All the Cleveland blocks use the same transmissions that the 289/302/351W's did. Same motor mounts too.
Thank you for the information. Do you have anything available on these engine block numbers...DOAE-L and D2AE-CA? Thanks again.
The D1 is listed as a 2 bolt 351C block, the D2 is listed as a 351CJ block, but don't let that pique your interest, that can be either a 2 bolt or 4 bolt block. The one I have is a 2 bolt. Been trying to sell it for 4 years now and no takers. It's never been apart, std bore, std crank no signs of anything wrong other than the stock timing chain stretched and it's riding up on the cam gear teeth.
