- Mar 20, 2009
- In the Middle
- Automatic
So how big is a 351 Cleveland? Is is the same external size of a 400? Between a 302 and 400?
hot rod car, are you from michigan? do you live near ann arbor? friends with dominic samiterno?
you running an aod with w3 etched in the top?? i built an aod for a cleve ranger out there about 5 years ago. dom at national built two cleve rangers, one had the dakota rack on it. there have been many from clements to down river i have seen over the years...
i did the c4 in doms personal truck and an aod he was needing to do for a guy near ann arbor. not allot of these things so i am wondering aloud here and hoping for a good report.
302 vs 351 c
When did I ever say that the Cleveland was a bad engine?Could it be your inference that it was ?
Yes I know that the engines that the Ford Nascar teams just replaced with the FR9 were Windsor blocks with Cleveland mains and yates heads are called Clevelands in your world. In the rest of the world they are known as 358ci Windsor engines with Yates cylinder heads. Here is a link to the RoushYates performance parts( http://www.roushyatesparts.com/Used-Racing-Engines-s/532.htmand )and they dont even offer any Cleveland parts
. Why is that? Are they just sold out?
Its becuse they havent used a Cleveland in Nascar in a long time!!!
Only Windsor's.
Hmm, that's not bad. I don't know anything about the 351C, but fordmike is the first guy I've ever heard say anything bad about themAbout the same width as a 351 Windsor, slightly shorter in height. The 400's deck is nearly 1" taller than the 351C, making it both wider and taller.
Hmm, that's not bad. I don't know anything about the 351C, but fordmike is the first guy I've ever heard say anything bad about them![]()
Better choices? Yes.I have said nothing bad about them. My argument is that there is better choises then the Cleveland for a Ranger V8 conversion.![]()
there might be better conversions....but this one is FREE![]()
Sale it to Baddad, blowhard hot_rod or some other other Cleveland lover for big money. You can get a 302/5.0 for cheap and have extra money left over to do more to your Ranger like exhaust, rear axle or custom driveshaft to name a few things.![]()
a custom driveshaft ?![]()
As in one that has been shortened to fit the truck with the V8 swap. If it been modifided its not stock its custom.![]()
Kicking each other in the nuts to see which one is still standing is useless and in the end ............everbodys nuts hurt.
OK, never had to do anything to mine when I first did my swap. The V6 shaft fit fine. Wasn't until the 331 trashed that shaft that I had to resort to a different driveshaft.
