Good morning. I have a 98 Jeep Cherokee that recently died on me after purchasing new tires. How much lift would I need on a BII to use these tires (if even possible)? The wheel bolt pattern matches 5x4.5 (114.3 mm).
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Same bolt pattern.Good morning. I have a 98 Jeep Cherokee that recently died on me after purchasing new tires. How much lift would I need on a BII to use these tires (if even possible)? The wheel bolt pattern matches 5x4.5 (114.3 mm).
With these older rigs youre pry going to be limited more on actual availabilty then anything.Can you all recommend a good lift kit that's sufficient and not too crazy expensive. Appreciate it
