I like easy.Y did u go with those motor mount and plate setup when most people on here say to use advanced adapters mounts or convertible foxbody 5.0 mounts?
On the plastic mock or the real deal block?I probably could.i don't usually c people asking for mock blocks muchIf you spend the money on a mock block, you can probably recoup your money trading it back and forth with other people....
When u c deals like that u definitely need to jump all over it.He had it listed as an '84 with no pics which is kinda meh, for the '87 roller I knew it to be as soon as I saw the intake and a few numbers I was all over it.
Easier the better manI like easy.
?We should probably hug in my basement.
I want a divorce.We should probably hug in my basement.
I want a divorce.
Here is a pic with the new motor,
Nothing special had to be done.
This is a 87 block
And the old one.
Was a 98 block,
I had to cut a relief in the adapter plate in one side for a slight difference in the casting.
I plan on trying the sn95 mounts.i was told there the exact same as the foxbody 5.0 very mounts.which sn95 is my donor car.we LL c how those work.i was told they make engine sit a tad higher that your regular plate rubber mounts do.but not sure how much more to make a difference
Good to know!i was wondering y people on here really never used the sn95 mounts or the foxbody very mounts.makes sense now.so the plates and rubber mounts set up use the existing hole on crossmember?no notching needed?how do the advanced adapters mounts work?y didn't u go that route?
What r u using for headers?the headman 88400s?I was told these headers fit the best?
