- Sep 22, 2007
- Michigan
- 2.9L
- My credo
- A legend to the old man, a hero to the child...
Glad to see your going down the road less traveled.
I think you'll be happy with the 300. The trick to it will be getting it to have power at higher RPMS. It can handle the Rev's, just dont make a whole lotta power that higher. You definatly will have quite a few advatages in the 4\6 class....
1- You'll have the biggest common gas 6 cylinder built (So no one can beat you in cubes)
2- While you do need high end horsepower in mud drags, you still need alot of torque to spin those big tires up to speed quickly, which is where the 300 is going to shine. If it were me id concentrate on making the best use of the 300's biggest strong point, low end torque. Concentrate on smoking people so bad off the line they cant catch ya.
3-Durbilty, your going to have a helluva time blowing that thing up.
4- Showing people that the 300 has potential.
Have fun and let us know how it turns out!
later,
Dustin
later,
Dustin
) ) for its debut in the pinto back in i belive 72...? the way they achieved the displacment for the 4.0 was to increase the stroke (also helped to lower emissions) the longer the stroke, the lower the revving capabilities. now i am not saying the 4.0 is not capable of high revs, not any less than a 300 that is. but if i were to stick with a V6, i would go with a SOHC 4.0, preferably out of a 05 and up stang. lets compare specs for a minute here. now i am not sure of torque numbers or peak levels for power or torque (call your dealer they will tell you in a heartbeak) but i know HP is 210..... thats the EXACT same as a 1985 mustang GT with a H.O. 5.O.... plus a bit of head work, manifold port matching, etc. also RE-Flashing the computer and putting larger capacity injectors/ higher pressure/flow pump... then you bump up the compression ratio... give it a hotter igntion.... but, i work at noon today.... so to all a goodnight
