My truck is a 1993 ranger 3.0L 4x4 and I was in the same boat you are. The stock intake is very restrictive! Altough my truck is a model newer, I don't think there will be much difference in the engine bay.
Here's the parts I used:
-1998-2000 ranger 3.0L V6 upper and lower intake manifold (aluminum)
-BBK 56mm throttle body for '94 to '98 mustang 3.8L
-1998+ ranger 3.0L MAC cold-air-intake
-Stainless steel braided throttle cable
-remote mount engine coolant tank
-dremel tool & dremel sanders/flapwheels
First off, I ported and gasket matched the manifolds. The upper I spent some extra time on because the throttle body flange is only 50mm factory so I massaged it out to 56mm for the bbk throttle body. There is some extra casting toward the rear of the manifold that will have to be removed to clear the distributer. Since this is aluminum, it does not take too long to remove material. About 1/8th inch, or so. This is not required for fitment, but I also smoothed the cast aluminum upper and laid some ford blue engine paint on it.
There is only two small modifications you need for the bbk throttle body. You will have to drill and tap two holes to mount your Throttle Position Sensor. The new holes are a little shy of 90 degrees of the original holes. Basically, make sure the throttle opens the TPS when the butterfly is open, but not when shut. The second mod isn't a sweat at all. You need another spring to help close the throttle. Otherwise, the bbk throttle body bolts right to the 98 manifold with no ugly gaps. It looks like it was meant for this. Same with the IAC.
Once you have this prepped, go ahead and remove the manifold, intake, throttle cable, and washer fluid/engine coolant tank from your truck. The new manifold is straight forward, just bolt it on. Same with the throttle body. (you should have bolted it up once already to mark where to remove material on the upper) So, go ahead and install the IAC, TPS, universal throttle cable, coil...
Since I had the Mass Airflow Sensor off, I did the MAF mod. It involves cutting the middle brace and porting the MAF body. I won't go into details with this since it's not required for fitment, but it does give about 20% more flow capabilities... for FREE! Here's more info about it if you are interested!
HTML Code:
http://rogueperformance.com/ModifiedMAF.htmlBack to the install. The MAC intake is straight forward. Use some ready rod and some nuts, bolts, and fender washers to support the heat shield to the wheel well. You will need to cut the engine coolant tank off of the washer fluid tank because of the obstruction it will cause to the air filter. Install the washer fluid tank back to its original location. Then, install the new remote coolant tank. I installed it on the old air box tray that sits on the wheel well.
Wait for the RTV silicone to set and dry, then start up the truck. Let it idle for a couple minutes to relearn its breathing habits. Two hours of driving should be sufficient for the computer to relearn everything.
I noticed,
BIG increase in throttle response
BIG increase in torque and upper rpm power
Nice growl from the intake
1-1.5mpg increase
And as a bonus, if you have an aftermarket exhaust, you will notice a deeper "muscle" note.
PS: I have an electric fan and Proform shroud which is considerably slimmer than the factory fan shroud. The MAC intake clears this easily, but it might be close for the factory shroud. Good luck!
