rurouni20xx
okay i have a 30 v6 thats toast, was looking to rebuild as 3.3, is this kit worth the money or should i consider another style engine? im looking for power w/o a turbo/super or nos as they are expensive, but im trying to find somebody that has done or seen the mod and want to know if theres a huge dif or if its just a waste of time/money as i could see a better increase in power from a dif engine. the reason i am considering this build is cuz i dont have to do any other modifications as far as changing wiring, transmission changes or messing w/ the wiring. if there wasnt much dif in the engine performance i will however consider doing another engine swap. another thing (that i will post in the tranny section) will the a4ld hold up to the added stress of the increased hp? ive read up that the a4ld has some strength issues as far as added hp applications are concerned. if the tranny wont hold up, im def doing a heart and leg transplant. no point of building up a motor if the tranny wont hold up. thanks for your time and consideration.
