jodom15sc
well let me first say, ive been around TRS for awhile and reading forums, just havent got around to posting anything. But this website is awsome!!
Well my problem right now is the engine temp. on my dashboard. After the truck is warmed up the needle sits half 1/2 way between hot and cold, dead in between and never higher or lower. But now it will go all the way to hot as if my engine is going to lock up or blow up, idk. Typically ill be driving and just going the speed limit and it will go to hot, im not hotroding my truck either. Once it goes to hot ill let up off the gas and the needle will either fall or stick there. Ive even come to dead stop and it sat on hot but sometimes when i hit the gas the temp needle will fall back down to half way where it should be. Ive tried to make it happen on purpose to see what it could be and i cant make it happen, even if i hotrod the hell out of my truck.
Ive checked my radiator for crack/leaks and nothing, and 3 days after the temperature needle problem, my check engine light came on...I went and had it read, it was a O2 downstream sensor, I changed it and engine light went off and temp. needle stopped. But now its back...any ideas on what to do??
i have a haynes repair book so i can do the basics
oh and this is my truck...99 2wd ranger 3.0, bone stock, just K&N filter, flowmaster 40s, general grabber AT2, 2 12"s
