ford96
- Feb 21, 2010
- Automatic
i have a 96 ranger 3.0 i bought it with a bad motor i changed that with a used one now when i got it running it has a mis that shakes the motor and mis at running rpm no power at all checked compression 120 to 150 in all 6 checked fuel pressure 35 at idle close to 40 when reved changed plugs and wires changed tps changed cam sensor pulled one spark plug wire at a time off coil pack and ran it none of them seemed to change the way it ran it also cuts out when driving and over drive light is flashing and hard shifts
