Alex FX4
- Dec 22, 2009
- Automatic
So heres some background info on my truck. Its a 2WD 1999 3.0l v6 Super cab running strong at 207k miles. There is something sloppy in the drive train so it jerks went you give it gas after coasting. I suspect U-joints but maybe rear diff. This is more of a slower paced build and i would like to get some opinions before i just start buying stuff.
I don't plan to get rid of the 3.0 ever. Its seems to be more reliable than the 4.0 even if it has less HP. i may rebuild it and its transmission someday but it runs good now.
Plans so far...
1. Rebuild rear axle with new gear ratio and replace u-joints
2. attach front and rear hitch so i can tow with the rear and put a winch on the front
3.Front and rear bumper/light guards with light bars and a roll cage.
4. Suspension lift, not sure what size yet. (don't want to get too ahead of myself)
Thats enough planning for now but i might do more as i go.
So im ready to start ordering parts for the rear end and rebuild it but i want i high quality locker but no too high quality if you know what i mean. The axle is the ford 7.5 with limited slip and i can go with a Detroit or a Lock-Right. Thing is that i hear Detroits don't break... period and that lock right's depend on carrier strength. But what will break first in a 7.5? axle shafts or the carrier? if its the shafts then why do i need a stronger carrier you know? so i'd like someones help on that as its my first obstacle.
As an added note, im running 29's at the moment with 15x7 rims. it will stay like that for a while as the tires are new but when they wear and i get new ones i'd like to know if there are any bigger ones i can find for 15x7 rims?
Plans so far...
