2in spacer lift problem
john47
I put a 2 in spacer lift on the front of my 2wd and now when there is no weight on the truck the upper control arms hit my chassis. I'm afraid the ballpoint is going to get messed up. Can I put different upper arms on? Or is there something else?
I hate it when my ballpoint gets messed up because I can't write anymore. On a more serious note. What you are describing sounds kind of odd. Can you post a couple pics of your installation?
Like if I hit a bump and my front end comes up the wheels drop out and my uppers control arms hit my chassis. I was thinking about putting 4wd upper arms on because in pics they look a little longer to give me that extra room. The only thing is I dont know if theyll go straight on. I put 2 Rancho RS 5279 shocks on the front with a doesche spacerlift. The shocks have Extended Length (in.) 16.375. And I think the OEM ext is 13 inches. It rides perfect other than when I get air and the tire drop it makes a loud noise and its def my balljoints hitting my frame.
