countryboy
here goes i am going to install 4.56 gears in my 8.8 and when i ordered the gears summit told me i needed the notched cross pin. i done have it but after some more research i found that i can just grind the ends of the ring gear a little and the factory cross pin will fit. my question is i done have the notched cross pin on hand and installing a lock-rite while i am at it should i use the notched cross pin since i am using a lock-rite.
