 - Jan 5, 2008
 - Frederick, Maryland
 - 4.0 V6
 - Automatic
- Tire Size
 - Round
- My credo
 - It was like that when I found it.
On a good day
 Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I need to just buy a damn service manual.
Copy. Guessing it's failing lean, but unsure. Will take a look at data logs.Just look at the fuel trims. Short term tells you the instant feedback of the fuel mix is vs what is commanded. Bad fuel pump would show positive numbers because the computer is opening the injectors longer to compensate for low pressure. Long term will tell you the average over time so again positive numbers means air leak or low fuel pressure. Pressure should be 65psi. Regulator is part of the pump assembly. (Returnless system). The regulator can fail wide open as well and jack up to 85+ psi which will cause a rich situation.
