2011 Interior wiring question.
Hawker Driver
ASE Certified Tech
Colorado
2004 and 2011
Not lifted
Total Drop
Not dropped
I am looking for a Ford tech that has access to the factory wiring guides. Harness 7L5T-14334-J4CP7 is plugged into the rear harness bundle and serves various cab functions aft of the front seats. There are 12 wires in the loom connector. I know what the Black/yellow stripe is but am lost on all of the others. What I really need to know is if any are continuously hot, regardless
You want this book: https://www.ebay.com/itm/285089604651
2011 Ford Ranger "wiring diagrams" by FORD, used to be called the EVTM
Ford sends this book out with the Shop Manual Set for every model they make and every year they make it
This book is often sold separately, used
And its FREE, kind of, you buy it for $50, use it as long as you like, and sell it for $50 when done, same as the person you are buying it from
Look around sometimes they can be found cheaper but watch the "shipping" charges
"But I only need the wiring for this one connector"
Yea right, until the next time, lol
And there is always a next time when vehicles get older than 10 years
Part number 7L5T-14334-J4CP7 doesn't come up
7L5(T) = 2007 Ranger part, which is fine to see in a 2011 model
14334 is a wiring harness part number, but generic applies to any Ford model
The J4CP7 is the oddball usually it is just 2 or 3 letters/numbers
J4CP7 is the build specification on the manufacturing tag attached to the harness. It refers to the harness that connects the main to the rear doors, Door ajar, seat belt tensioners, speakers, dome light and cab rear mount light. It has a 16 pin connector at the end.
