2010 ranger hid questios
Tb8983
Forest Grove, OR
I have a 10 ranger and I have a hid headlight and foglight kit and they both won't work it's either one or the other. Is there a way to make them both work and I have heard of a relay or another part to make it work. Any help or input would be great
it's illegal to run high beams and fog lights at the same time, there's a reason it disables your fog lights when you turn on your brights.
No I think you misunderstood me no I meant low beam and fog light I know it won't work with the high beams I meant it with the low beams. They don't work it will work with the parking lights and fog lights will work. With the headlights on and the fog lights won't work
what i did when i put my baja lights on to get rid of the high beam problem is i installed a new fuse block into my truck, hooked it to the battery and grounded it. then i put it to a toggle switch in the dash, so then you can run them with high beams on , just make sure there's no cops around;) that'd prolly work for ur original problem tho
