2009 Ranger PATS Mystery – Will Erase/Relearn Original Keys but Refuses Any New Keys
I'm stumped on a PATS issue with my 2009 Ranger and hoping someone has run into this before.
Truck:
I have two original factory keys that work perfectly.
I can successfully:
Here's what I've tried:
Because I can erase and relearn the original keys successfully, I believe I've ruled out:
Any ideas for additional FORScan diagnostics, PATS live data, DTCs, or tests would be greatly appreciated.
Truck:
- 2009 Ford Ranger XLT
- 4.0L SOHC
- Build date: 02/2009
- VIN: 1FTYR15E49PA33204
- FORScan (Extended License)
- OBDLink EX interface
I can successfully:
- Erase all keys.
- Reprogram both original keys using FORScan.
- FORScan correctly reports two programmed keys afterward.
- Four different new 80-bit transponder keys.
- Keys came from two separate purchase lots.
- These are not cloned keys.
- They are the same style of keys I've successfully programmed on other Rangers.
- I've tried both the onboard spare-key programming procedure (using two working keys) and FORScan's "Add Ignition Key" procedure.
- Neither method works.
- PATS memory corruption.
- PCM/cluster synchronization issues.
- Security access problems.
- OBD interface problems (using OBDLink EX).
- Programming procedure/timing errors.
- A known issue with certain late-2009 Ranger instrument clusters.
- A PATS firmware/calibration difference.
- A configuration setting I'm missing.
- Something else unique to these trucks.
