2007 Red Trailer 4X8 Utility Trailer
That is always a possibility as well. The reported shipping weight is either 300# or around 200#. 200# makes more sense since the RTT is 176# but who knows. Maybe it's just the way the shipping company compensates for a large, bullky item as far as the rate they charge. šŸ¤·ā€ā™‚ļø
Probably 176# plus an oversized wooden pallet. Have some snips ready to cut it loose from the pallet and shed some weight for lifting it out of the truck.
If you're lucky, what ever box truck or short semi that pulls up in front of your house will have a lift gate. Then he can wheel the pallet out onto the lift gate and lowered it to the level of your trailer. You back up to the lift gate, slide the whole mess onto your trailer and go back it into the garage. Easy-peasy.
I'm not counting on being lucky. I have diagonal side cutters, tin snips, and other plier type tools. I've found the two pairs of flat jawed pliers work best at controlling the ends of the banding and cutting the banding at the same time.
Some pictures and links of the Timbren Axle less Trailer Suspension system that I'm prepping for installation on the trailer. I still need to get some good Timken bearings for the hubs since they came with made in China bearings. I'll keep the Chinese ones as spares, just in case.
Suspension: https://timbren.com/products/asr1thds01-axle-less
Tires: https://www.etrailer.com/Trailer-Tires-and-Wheels/Kenda/AM3H390.html
Hubs: https://trailerparts.com/5-on-4-5-bolt-circle-with-68149-44649-bearings-1-3-8-x-1-1-16-i-d.html
Suspension arms and spindles hanging so the paint can cure. 1/2" grade 8 hardware is on the sawhorse table drying as well.
The hubs are sitting on the floor so the paint can cure on them as well.
Some of the hardware needs to be flipped tomorrow so that they can be painted tomorrow. Then I can work on the 2' X 2" X 49" 1/4" wall square tubing and the wheels for the tires. The tubing and the tires will be painted directly to the color they are going to be when the job is done. The suspension, spindles, and hubs got painted Deep Forest Green and then other camo paint will be added after installation to emulate how military equipment during the Cold War era were painted. Plus, the trailing arms are built to be like skid plates since they will be the most likely parts to hit something. They will need the extra paint.
All set to start work on the suspension. The bench to do work has been setup over the tongue so that it is easier on my back to work on things, like running the drill press. Though, it may need to be taken down an put up a few times when setting toe and taking measurements to make sure everything is equal from side to side.
The brush guard steps, fenders, hub spacers, and tires have been removed.
The axle and springs have been removed. The frame was checked for square. And I made sure the mark for the spindle location on each side was the same distance from the front of the trailer. Well, as close as I could get it with a tape measure and a sharpie marker.
The bearings have been greased and installed into the hubs along with the inner grease seal. The outer cap is just lightly set in the hubs to keep dirt and debris out. And the spindles have been bolted on to the suspension arms.
The spindle location has been marked on the frame as well as where the front and rear of the mount bracket are expected to mate up to the frame. The front section of the original suspension u-channel has been marked for removal. I'm also going to need a section 2" X 2" X 3/16" angle iron to fill the gap in front of the angle iron used to secure the folding rear section of the deck and provide something for the suspension to mount to. Until that all gets done, the installation will have to wait. I expected this. I just didn't know how much of what was going to be needed until I had the physical part in front of me.
Well, I made a bit of progress. It took a bit longer than expected to get one side done, but not horrible. I found two bolts that I had forgotten about that will need to be addressed. I'm thinking of machine screws with a tapered head and bevel the holes so I can clamp the suspension mount to the frame for drilling. Then locate the holes on the mount so I can drill holes into the suspension mount to sandwich the whole thing together. Hopefully, both locations will be where I can drill through and use a regular hex bolt. If not, a tapered head machine screw is better than nothing.
I got back to work on the trailer. The holes have been counter sunk on the existing frame so that 10.9 flat head machine screws could be installed. The 2" X 2" X 3/16" hot rolled angle was cut in half and drilled for bolts in the front, where they will clear the suspension base and countersunk for a machine screw in the back.
The spacer will need to be taken back off for priming and installing everything with paint able RTV in between the layers to prevent water intrusion.
The angles to fill the gap where the suspension mounts will sit are primed and installed wet with acrylic RTV. The bolts and machine screws were installed wet and the nut side has been sealed as well. Now to wait for that all to cure and give all one last spray with some primer before I start figuring out how I going to get the suspension arms up so I can clamp them in place for drilling the holes to install the mounting bolts.
Right side
left side
damn...i been missing out.
Yeah, the old girl has been in need for some TLC and a suspension upgrade. The nearly 20 year old axle and springs and showing signs of the use and abuse they have gotten over the years.
The bearings and hubs were in great shape but the axle has a profile like this
/----\ which is causing accelerated wear on the inside of the tread. So, it's been time to do something about it before installing new tires.
The new suspension is rated for 2,200# and comes with 3,500# spindles. The suspension design will also give more ground clearance since there is no axle beam down low to catch and hang up on things. To compensate, there are receiver like tubes in the suspension mounts to run a 2" X 2" X 1/4" square tube across, tying the two sides together so the frame doesn't get tweeked and bent.
It will also give the trailer a slight lift. Something like 1" - 1.5". Being that the OG springs are old, the lift might end up being more than that just because of spring sag. We'll see.
i been thinking of building a baby dumper that can hold 3 bikes or have a topper to enclose/camp out of. i need to move a shit ton of fill at home. nephew will loan me a d4 for a spell. i had a line on a pickup dump box for a good price to base it off of. i need an intermediate trailer so it seems like a good idea. but i want it off road capable as well. torsion axles might be a good option.
i was going to go with air bags....but thats a potential complication that may prove disasterous. i would need to keep more battery and air source power that the already heavy hydro dump system is hogging up....
Torsion is definitely easier than what I'm doing. I can't remember if it was cheaper or not.
As usual, I have to be different than what most people do. Supposedly, this axle system is supposed to be pretty good off road.
The only thing better is independent trailing arm suspensions, like what the Aussies use on a lot of their trailers.
This frame isn't real friendly to the Aussie system and is beyond the tools, equipment, and fabrication knowlege I have at this point. A square tube or rectangle tube frame is a better candidate for that type of suspension than the C channel one I have.
