2007 ranger swapped out dash wiring harness now need help with clutch safety switch
ranger10
i need some help , I changed out the dash wiring harness to add power windows and mirrors ect, the problem is the harness came from auto trans truck and i have manual trans so no plug for nuetral safety switch. any advice on fixing this problem of do i have to take appart virring harness would prefer quicker fix thank you.
If you know which are the wires for the neutral safety switch on the auto harness just wire them onto the clutch switch and you should be good to go.
I always bypass mine anyways. You can start it from outside the vehicle and in an emergency, for example, if you cant get it to run you can use the starter to move off the road safely.
Find the two biggest wires in the park/neutral switch plug connector, and wrap them together.
