2007 Ford Ranger fuel gauge reads backwards after pump replacement (sender curve issue?)
jcwhidby
5+ Year Member
Virginia
I’ve got a 2007 Ford Ranger (fleet vehicle) and ran into a strange fuel gauge issue after replacing the fuel pump module.
After installing a new pump/sender assembly, the fuel gauge now reads completely backwards:
  • Full tank shows EMPTY
  • Empty tank shows FULL
Here’s the key detail that’s throwing me off:
The original sender I removed measured high resistance at empty and low resistance at full (opposite of what I expected for a 2007). The new pump appears to be the more typical Ford curve (low resistance at empty, high at full), which explains why the gauge is now reversed.
So it seems like:
  • Truck expects: high resistance = empty
  • New sender provides: high resistance = full
A few questions for anyone familiar with these:
  1. Did some 2006–2007 Rangers (especially fleet units) use the older Ford sender curve (~160Ω empty / ~15Ω full)?
  2. Is there a known correct Motorcraft or aftermarket part number that matches this “reversed” curve?
  3. Has anyone successfully swapped just the sender onto a newer pump module on these trucks?
  4. Any known differences by engine (this is a 4.0L) or fuel tank configuration that would explain this?
  5. Just to confirm—there’s no PCM or cluster programming option to invert the gauge, correct?
I’ve confirmed with a multimeter that the new sender is opposite of the original.
Trying to avoid dropping the tank a second time—any insight from someone who’s run into this would be greatly appreciated.
Thanks.
Could the float arm have been installed reversed?
Replacement parts quality is really bad these days.
Good question. The float arm would only go one way. I pulled the pump back out of the tank and tried to see if it could be swapped.
Didn't that change from 88-89?
To close the loop on this, it the Amazon pump level sensor had a reversed sensor curve. I bought a Carquest one for a 2007 and the sensor curve was correct. I would suggest checking the sensor curve on old and new pumps prior to installation to prevent having to remove the bed multiple times to change the pump.
