2007 Ford Ranger - Disable Daytime Running Lights (DRL)
Possibly. It seems dumb to backfeed a PWM power supply with steady voltage. In fact, as an electrician, I'll say it feels wrong to do that.
A diode would prevent backfeed though, is it possible the diagram doesn’t show a diode or a diode is used internally on the module to prevent backfeed?
It's possible. Either way, the diagrams are vague and we don't have a nice, neat way to remove or disable the circuit.
I’ve actually wanted to get a DRL module for my green Ranger but I don’t want to pay new replacement part cost. That one is simple, it’s just a little module that plugs in on the core support. Don’t know why they had to go and make it more complicated. That’s my common beef with manufacturers and engineers, they keep making things more complicated instead of simpler and reliable.
There's one from a 96 Explorer right here in my living room.
Wonder if it’s the one I need, apparently there were at least two different plug styles for those
Oh, sorry. It's just the shorting jumper for vehicle without DRL. I thought this Explorer had ALL the bells and whistles.
I trashed one from a 91 when I first did my swap. Along with the connector for it...
Yeah, both of the Eddie Bauer Explorers I have just had the shorting bar and not the module. Seems weird but whatever.
if a 2005 is the same as a 2007, this is a 2005 diagram.
there are probably circuits in the DRL driver that isolate it when the low beams are activated.
sorry, my rotational skills are sort of MIA tonight.
  • 2007 Ford Ranger - Disable Daytime Running Lights (DRL)
To close the loop on this, I ended up putting an automotive relay in the wire that goes to the low beam +12v wire near the light socket and used the parking light +12v wire as the relay trigger. I put one relay on each side to reduce the potential for a single relay failure to take both headlights out at the same time. This removed the DRL function effectively except it prevents turning on only the parking lights without the low beams which isn't an issue for me.
Workarounds FTW.
