cbxer55
- Oct 9, 2009
- Automatic
Well, did you get the new fuel pump in the beast yet? Or are ya procrastinating on that?
New pump is in and working. Turns out you pretty much have to pull the bed to do it, lol. While they had the bed out of the way I hit a bunch of the frame with fluid film. Could use some new bed bolts and some rust repair on the bed when I can get to it this year. Seems to run a lot better now, lol
Sent from my kite using a trebuchet
It's either pull the bed or drop the tank. If the tank is almost empty, that's the easy way. Glad to hear it's running better, it should be.
On mine, I found those bolts under the dash for the shifter. There are four of them on mine, two under and two atop. All four were loose. Three just a half turn or so, but one of the top ones took three turns to get tight. Shifts much better now, and the not starting in Park is done for. Didn't have to remove anything to do it, just laid on the floor on my back, shined a flashlight up there and tightened them with a screwdriver with a T30 bit in it.
Glad to hear it! Now, you can devote your full attention to your recovery. Back in the saddle in no time.
Well, I still need spare keys and the one brake cable is sticking and some other odds and ends. But it's nice not having to hope it starts anymore and the other stuff is relatively minor so there's no big rush.
