2.5L ('98-'01) 2000 2.5l wont start
jjpp250
Central, CA
2.8 V6
5.5” + 2.5”
32/11.5/15 33/12.5/15
working on 2000 2.5l 8 plug for the neighbor, she said it died and wouldnt start. I have read tons of post about this but still having troubles, Iread if the check engine light goes off while cranking that the cam sensor is good.... its got power at the coils, it has spark at the plugs using a spark tester, good fuel presure, it wouldnt start with starting fluid. new battary, what needs to be tested next? i know i am missing something Thank for taking time to read this and thanks for any feedback
Well... you have two of the big three when it comes to starting. Spark and fuel. The third is compression.
Pull a plug and check compression. Inspect the plug and ensure it's not flooded. There should be a presence of fuel just not wet.
If flooded, the clear flooded engine procedure is to hold the gas pedal to the floor while cranking the engine. This tells the computer to not send spark while cranking.
Close...
It stops the fuel injector pulses .. but keeps sparking.
I didn't see it mentioned but I would make sure the timing belt is still there and working, there's a plastic plug on the front of the timing cover that you should be able to see the belt through, if it's floppy in there it needs a timing belt, it's not an interference engine so no worries if it did go...
From experience, the sound it makes when cranking with a broken timing belt is quite noticeable.. but it could be missed since it's not his vehicle
Yeah... it's sounds like your cranking the engine with the spark plugs removed.
Just to be safe,
Any body have any tricks to put the spring back on a new tensioner? I haven’t took the old one off yet but it seems to me it’s pretty strong. I have never took one lose, if it’s a pain than I am going to leave the old on, it’s not bad anyway it just came in the kit.
It's way simpler than it looks, definitely change the tensioner if you have one. As dumb as it sounds the best tool I found to compress the spring is a claw hammer... get the claw between the spring and the pulley and pry it away after loosening the pin bolt a little bit (also loosen the spring bolt a little) so it moves then unscrew the pin now release the tension on the spring and you can take it off and repeat.
Once you have the new one on, compress the spring to the end of the slot and tighten the pin bolt, once you have the belt on and aligned loosen the bolt and let the pulley hit the belt then rotate the crank two rotations to verify the belt alignment, once the marks are lined up tighten both tensioner bolts with no added tension (I've been tempted before, it's not necessary).
Main hard part of the process is getting the power steering bracket out of the way with those 3 blind bolts, which reminds me when I change the pump I should probably just do that...
